[TurboGrid] Error while importing CAD flow domain centrifugal impeller
Like Tree2Likes
  • 1 Post By kazzy
  • 1 Post By zacko
Old   May 9, 2024, 06:53
Exclamation Error while importing CAD flow domain centrifugal impeller
kazzy is on a distinguished road
I am using Ansys Turbogrid to mesh centrifugal impeller. Importing the CAD fluid domain into turbogrid. Later, using the mapping techniques I have selected necessary edges and faces. However, it gives me error message stating ''Proflies could not be generated for the blade. This is likely because of gaps or hole in the geometry."
You help will be much appreciated. Thanks.
https://ibb.co/bR9k6rC
kazzy is offline   Reply With Quote
Old   May 19, 2024, 07:07
Daniel
zacko is on a distinguished road
I have never imported a CAD into TG but is it correct hat there is no face at the leading edge? I can see the curves of the profile but no surface. At the trailing edge there is one modeled. Maybe this is the gap that is causing the error?
zacko is offline   Reply With Quote
Old   May 19, 2024, 07:24
Thanks appreciate your response. I have tried selecting all the edges for leading edge. However same error if popping up again
Old   May 19, 2024, 07:36
Also it does ask for leading edge so I suppose surface you cannot select it has to be edges only
zacko likes this.
Old   May 19, 2024, 08:51
Daniel
Is it possible in your CAD model to draw a line from hub to shroud at the leading edge? Maybe TG can then recognize the leading edge better?
Old   May 19, 2024, 09:08
Zacko I have tried that out with creating another line and surface also for leading edge. However same error is poping up for every best attempt I do.
Old   May 19, 2024, 09:24
Daniel
Hmm weird. Maybe someone else will reply with a solution.
kazzy likes this.
mesh, turbogrid
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 12:16
Full Impeller Domain In CFX Pre after Turbogrid Messhing of a Single flow passage stephec1 CFX 2 February 11, 2023 11:54
[TurboGrid] How to best model centrifugal pump impeller and suction domains using TurboGrid jgross ANSYS Meshing & Geometry 1 December 28, 2021 17:10
Can I achieve better convergence? sheaker CFX 12 September 19, 2019 15:36
Modeling the flow domain in Icepak saisanthoshm88 Main CFD Forum 0 April 11, 2011 08:31
