[GAMBIT] Meshing for eppler423
Old   April 19, 2009, 16:29
Post Meshing for eppler423
Vishnu
agnithepower is on a distinguished road
What kind of meshing is required for eppler 423.If c-mesh is required can anyone explain the kind of procedures like meshing of its edges.whether it is first length, successive ratio etc. for its edges?
agnithepower is offline   Reply With Quote
Old   April 20, 2009, 01:39
Janarthanan Alagesan
Alagesanj is on a distinguished road
Hi Vishnu,
For airfoil flow analysis C - type mesh is widely used. In some cases like rounded trailing edge O - type mesh is more suitable. I assume you are using E423 airfoil with sharp trailing edge.
You can use first length, last length, successive ratio or the combinations of all, but all depends on how you split your edges and how you want to distribute the points on the airfoil surface. The important factor is more points are needed at the leading edge and trailing edge.
So use trail and error method to find the best option.
Cheers,
Alagesan.
Alagesanj is offline   Reply With Quote
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
