Edge degenerates into point
Old   July 15, 2009, 12:31
Default Edge degenerates into point
Mirco Magnini
magnounibo is on a distinguished road
Hi everybody, I got a very unusual trouble with gambit: I have to connect two vertex in a edge, which would result in about 0.4 mm length. But gambit decides that it can't connect them, giving the following error: <<the edge degenerates into a point>>.
I try to search in defaults menu for the correct option to change but I can't find anything...
Can anybody help me?
Thanks in advance
magnounibo is offline   Reply With Quote
Old   July 17, 2009, 03:19
-mAx-'s Avatar
Maxime Perelli
check if you don t have superposed points
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
Gambit error- the edge degenerates into a point Jai FLUENT 1 September 23, 2006 04:00
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 01:07
Gambit degenerates an edge to a point Tomas FLUENT 1 December 4, 2004 04:33
