July 24, 2009, 15:05 |
Problem connecting faces in Gambit
Acoidan Betancort Mondesdeoca
Hi there,
I'm following the airplane Gambit tutorial to mesh my 3d automobile geometry, but I have a problem when I want to connect the symmetry faces. I don't know why, but sometimes it works well, and sometimes I get this warning: "The call to connect on list of faces resulted in no actual connect operations." And of course, symmetry faces are not connected at the end. Do you know what it is happening? Thank you very much Acoidan |
March 15, 2010, 06:57 |
I'm having the same problem with Periodic faces.
Can someone help us ? Thanks |
March 15, 2010, 08:24 |
Maxime Perelli
Rep Power: 41 |
I don't know if it helped the other member
http://www.cfd-online.com/Forums/ans...l-problem.html Let me know if it helped
In memory of my friend Hervé: CFD engineer & freerider |
March 15, 2010, 08:31 |
Finally I followed that tutorial and dealed with the problem.
Thank you very much |
October 10, 2016, 00:59 |
Maxime Perelli
Rep Power: 41 |
Converting virtual to real entities isn't good idea, because it will failed for sure.
Converting Virtual Faces to Real Faces in Gambit | gstraw | Main CFD Forum | 0 | June 19, 2009 07:11 |
connecting walls in gambit | Amir Khodabandeh | FLUENT | 0 | March 30, 2007 14:17 |
Gambit error: cannot select faces and volumes | smillerhh | FLUENT | 1 | December 15, 2006 09:07 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 08:42 |
Startup Problem in Gambit 2.2 with WindowXP | Win Win Maw | FLUENT | 3 | January 25, 2006 11:09 |
