[GAMBIT] Splitting Volume Error
Old   April 20, 2010, 03:40
Default Splitting Volume Error
chris21 is on a distinguished road
I made a relatively simply shaped edge outline, created a face, and used the sweep face function to create a volume from this face. I tried to split this volume with another volume and got the error: can't operate on volume because it is linked for meshing, please remove links. I'm not sure why this is happening, but I haven't even dealt with any kind of meshing or links that I know of. How do I remove links or do whatever is required to split the volume?
chris21 is offline   Reply With Quote
Old   April 21, 2010, 01:14
-mAx-'s Avatar
Maxime Perelli
in the mesh panel, go to volume (or surface). There is a icon Link Volume/Surface Mesh.
Right-click on the icon and the Unlink option appears.
Select All an apply.
Then retry your split
Old   April 21, 2010, 20:26
Default Problem Solved
Thanks! I was able to get the split to work. I thought I tried unlinking the volume, but I must have overlooked it!
Old   May 2, 2011, 22:30
Default Hi
goyalnn is on a distinguished road
I have created a person (made of different volumes) in GAMBIT. The person is standing inside a big cube which in itself is a separate volume. I want to study the air flow inside the cube. Do I have to first split/subract or do anything like that with outside volume and the volumes inside it (person) or Can I just go ahead and create edge,face and then volume mesh for the whole thing without specifying any such relation between them?? someone told me it is necessary to split but when Im trying to split the person from the outside volume, it gives me an error "coincident face_face_ints with different body vertices". Can anyone help me??
I would greatly appreciate your response.
Thanks!
goyalnn is offline   Reply With Quote
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
