GAMBIT-meshing 20M elements with 3gb ram ???
Old   May 17, 2010, 07:02
Default GAMBIT-meshing 20M elements with 3gb ram ???
kdrbrk's Avatar
Burak
kdrbrk is on a distinguished road
I heard that we can mesh as much as we want by dividing the flow volumes into many sections. Than saving them each time.
Ex:
Lets say the mesh you want needs 18gb RAM.
You have 3Gb.
Then you divide your flow wolume into 6
Mesh each of them, and save.
Close GAMBIT, open it again.
Keep meshing 6 times
Than you have 20M elements mesh...
Can it be possible? And how do we connect these meshes?
kdrbrk is offline   Reply With Quote
Old   May 22, 2010, 07:22
Walid JARRAH
wjarrah is on a distinguished road
Send a message via MSN to wjarrah Send a message via Skype™ to wjarrah
Hi
When you reopen your .dbs (or whatever it is) file, to mesh the remaining volumes, I think that Gambit will load the already meshed volumes into your ram, so I am not sure meshing the whole volume part by part will help, but I can be wrong (I am a beginner)
But I know you can connect face meshes with the "Face mesh connect" tool located in the mesh command panel (or is it the geometric command panel)
Check all the box and search for "connect/link faces"
I hope this helped you
wjarrah is offline   Reply With Quote
Old   May 25, 2010, 01:41
-mAx-'s Avatar
Maxime Perelli
You can work and create such mesh with your hardware configuration.
But the problem will come as you will try to export your mesh.
The workaround could be to create one dbs file for each volume (or several volumes), and define interfaces between volumes you export.
Then load each mesh in fluent : the first one as usual (file/read/case..) and the other with grid/zone/append case file...
Reconnect your meshes by defining interfaces (define/interface...)
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
3d Gambit meshing shows out of memory tamjid FLUENT 3 September 27, 2008 01:01
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
