divide a face in order to have different boundary conditions |
May 27, 2010, 05:24 |
Hi all.
I have a rectangular box.I pretend to divide the bottom in two different zones in order to give them different boundary conditions in these zones. I am not being able to do that. Does anyone have a suggestion to do that? Best Regards. |
May 27, 2010, 06:17 |
Ke peng
In ICEM, just to set different face with different part name.
btw, it is very easy to do so in Fluent. Select the menu "grid", then "separate" Last edited by kepeng; May 27, 2010 at 06:18. Reason: add info |
May 27, 2010, 06:21 |
Sorry,
I forgot to mention that I am using CFX Regards |
June 7, 2010, 05:37 |
Hi all.
If anyone have a similar case to mine you can divide the bottom of the channel using the Operation Imprint Faces in the extrude feature from the 3D features toolbar. Regards |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Help with boundary conditions | Dan | CFX | 0 | April 3, 2006 11:32 |
