[ICEM] generating tetra mesh on various cylinders at the same time |
July 7, 2010, 12:12 |
Karan Anand
Hi
I have a geometry where I want to create a hybrid mesh. There are 36 cylinders all oriented differently but about the same size. I want to create a volume mesh in the 36 cylinders of the same size and type (tet preferred). The problem is that the cylinders are spaced apart from each other and linked to a common geometry which has a mesh of its own. Is it possible to mesh the cylinders all together in one go? or do i have to create separate body names for each cylinder and then mesh each one individually? I tried meshing it in one go and the model states I have holes in the model as expected! I want each cylinder volume to be water tight but each cylinder is separated and i don't need a mesh in between. Last edited by karananand; July 7, 2010 at 13:04. |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
TGRID- Problem in generating Viscous Mesh | abhinit | FLUENT | 3 | January 8, 2007 08:48 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
