[ANSYS Meshing] ANSYS 14.0 Workbench ICEM CFD Interactive meshing |
May 27, 2013, 11:05 |
Rep Power: 13 |
I'm trying to do a similar meshing like in this tutorial video: http://www.ansys-blog.com/2012/10/04...d-interactive/ At the beginning in ICEM CFD I want to replace the initial block by a new one - so I did it like in the tutorial and closed the blocking, generate a new initial block with the name of the deleted block and associate the edges. If I generate the pre-mesh, convert it to unstructed mesh and go back to the workbench meshing I get two errors with a long unspecific text which meens in rough translation that some elements can't assigned to some objects... Nevertheless the mesh is correctly shown but can't used. In both cases I used the default values and changed nothing from one try to the other. So I tried a lot of things and come to the following: - if I use the automatic generated block everything is fine - if I replace the initial block with a new one the errors occur It seems that the automatic generated block is 2D because I only get a mesh on the surface of my geometry but I need a 3D mesh. (I also tried to replace it by a new 2D block - I doesn't work, too) So what can be the reason and how can I get it working? I hope somebody can help me... Update: Okay the automatic generated block is 3D swept block. I tried to change it to mapped but it doesn't worked because the "corners are not clear". Last edited by Bill Tuer; May 27, 2013 at 11:55. Reason: Update |
May 29, 2013, 11:49 |
Matthias Voß
Rep Power: 20 |
did you associate ALL points and lines in your blocking?
May 29, 2013, 13:17 |
Rep Power: 13 |
Yes, but I think thats the point.
I tried several things, e.g. just to disassociate one vertice or one edge - and then the back transfer failed. But I didn't get it with a new block working, either. I split the block several times and associate all vertices and all edges to points and curves. The inital block is a single one (swept) and all vertices and edges of this one are associated to the geometry. But I want to have several splitted blocks to get a straight mesh. |
May 30, 2013, 03:51 |
Matthias Voß
Rep Power: 20 |
i would guess it is because of the changed blocktype.
are u running 14.5? There is a new ICEM container which i am using all the time, and a tcl/tk script and everything works quite well (updating geometry, automatic hex meshing with different blocking, and mesh refinement e.g.) |
May 30, 2013, 10:51 |
Rep Power: 13 |
No, as I mentioned in the title I am running 14.0 and I don't have the possibility to use 14.5.
My intention was to use the interacitve ICEM meshing inside a Workbench remeshing script. But in the meantime I have to notice that this doesn't work. If I start the meshing process the recording stops with the hint that a batch process is starting which can't recorded. So it seem I have to find another way to realize my project... Maybe I start a new thread on this topic - I want to remesh in ICEM with an updated geometry after a non uniform deformation on a boundary (CFX) - or has someone a tutorial or good source as a starting point for me? |
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes | rooftop | ANSYS Meshing & Geometry | 19 | March 31, 2016 02:33 |
Scale meshing ANSYS ICEM CFD | Giannis191919 | ANSYS Meshing & Geometry | 0 | September 30, 2011 05:47 |
Tips of ICEM CFD meshing speed up | CFD_D_BOY | ANSYS Meshing & Geometry | 1 | September 7, 2011 02:53 |
Complex .stl data for volume meshing in ICEM CFD | Nils_H | ANSYS Meshing & Geometry | 5 | September 2, 2011 08:39 |
Wind tunnel hexa meshing in ICEM CFD 12.1 | matheusguzella | ANSYS Meshing & Geometry | 1 | March 14, 2011 16:14 |
