[ICEM] Meshing problem from ICEM CFD to Fluent
Old   September 14, 2010, 03:59
Default Meshing problem from ICEM CFD to Fluent
Rafael
cfdonlinederafa is on a distinguished road
Hello.
I have an hexa mesh and in ANSIS ICEM looks pretty good, but when i export it into fluent, some problems appear.
I attach two pictures of an horizontal plane with a z=1 with ICEM CFD (scan plane option in Pres-mesh) and the mesh charged in Fluent
Icem Mesh: every cell looks ok hexa as i want
Flent: the mesh has some problems it appears some triangles.
Does anybody have the same problem?
Could you help me? Thank you very much!
Rafael PhD Student
cfdonlinederafa is offline   Reply With Quote
Old   September 21, 2010, 14:36
Default Elemental display issue...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You may just be viewing a cut thru some elements so it appears like that... Check your mesh types when the mesh is actually loaded to see if you really have any non hexa or quad elements. I am guessing that everything is just fine. It is just a display thing in Fluent.
Instead of showing the cut thru the elements, try to display whole elements... That should sort it out.
Sorry, I forget where this control is in Fluent.
Simon
PSYMN is offline   Reply With Quote
Old   September 21, 2010, 16:16
Rafael
Thank you, i guess it must be that... becouse everything are quads and hexas...
but i can not find the option you tell me about in fluent... anyone can help?
Thanks!
ansys 12, hexahedral mesh, icem cfd, problem
icem cfd ai environment 11.0, laptop keyboard problem, linux pertupd Hardware 3 October 3, 2011 08:27
Missing tets along line when meshing with ICEM CFD Georges P. Côté CFX 6 March 23, 2006 00:34
ICEM CFD 5.1 problem with tetra count Baskaran CFX 2 March 13, 2006 12:59
Problem with ICEM CFD 5.0 sac CFX 4 October 15, 2004 11:28
Problem importing IGES files into ICEM CFD Patrick Main CFD Forum 2 December 6, 2001 12:44
