[Other] Ansys meshing - periodic mesh for fluent
Old   September 14, 2010, 11:30
Default Ansys meshing - periodic mesh for fluent
jsm
JSM
jsm is on a distinguished road
Dear All,
I tried to mesh my geometry with periodicity (through match control) in Ansys meshing. I always getting some topology error. Then I tried for very simple quarter part of cylinder. There also I got the same error.
But AM is meshing the same geometry without match control. Unfortunately, help also not explaining this in detail. There is any way to mesh the geometry with periodicity in AM?
With regards,
JSM
jsm is offline   Reply With Quote
Old   September 16, 2010, 07:29
jsm
JSM
Is it possible to do periodic meshing in Ansys meshing?
Any one give me some suggestions to do this?
With regards,
JSM
Old   September 16, 2010, 13:38
Sean Delfel
delfel is on a distinguished road
Hi jsm,
I struggled with this as well (the transition from Gambit has not been an easy one...). The best method I found was to convert the faces to periodic boundaries within fluent itself using the command line.
Basically, I use the Named Selections in the mesher to name the two faces which will be periodic "periodic.1" and "periodic.2". Then, once the mesh is loaded in fluent, type mesh -> modify-zones -> make-periodic. "periodic.1" will be your periodic zone, and "periodic.2" will be your shadow zone.
I haven't played with the feature to enough to know if it has issues with the faces having different mesh topology, but I'm guessing you'll need to do something in the mesher similar to linking the meshes in gambit to ensure the faces/edges have identical meshes.
Cheers,
-sean
delfel is offline   Reply With Quote
Old   September 17, 2010, 05:28
jsm
JSM
Hi Sean Delfel,
Thanks for the reply. Yes. I want the same kind of feature (linking the face meshes) available in gambit. I will try in AMP once again to find the way to do this.
With regards,
JSM
Old   September 24, 2010, 14:25
Sean Delfel
Hi jsm,
Not sure if you've solved your problem yet, but you can do the equivalent of linking the face meshes in Gambit using the "match face meshing" control in the Ansys mesher.
Cheers,
-sean
[Other] 2D Rectangular Mesh in Ansys Meshing Belgio ANSYS Meshing & Geometry 8 February 10, 2017 04:01
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 02:39
Importing mesh files from Ansys into Gambit Srinivas FLUENT 2 August 6, 2002 10:02
