September 23, 2010, 06:33 |
how hexahedral mesh is done
harry
hello,
i am very new to this field. i am working on centrifugal pump. i was told to to do hexahedral meshing of the pump. since it's casing, water passage and impellor are not simple geometry(i.e. with continuing changing cross section). wat can i do abt it. |
September 23, 2010, 06:35 |
harry
urgent plz reply
October 1, 2010, 03:09 |
qx
you may have to use ICEM. You may find that it is hard ,even impossible to use GAMBIT to do hexahedral meshing for a complicated geometry
October 1, 2010, 04:56 |
harry
October 1, 2010, 08:48 |
qx
December 10, 2010, 07:44 |
harry
i am working on centrifugal pump. the solution of the pump is not converging. the graph that is plotted during iterations shows very fluctuating lines. wat can be the problem. kindly reply.........
gambit 2.3 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
Hexahedral Mesh Generation software | makotohonda | Main CFD Forum | 1 | July 14, 2010 00:04 |
[Other] Hexahedral mesh generation | makotohonda | OpenFOAM Meshing & Mesh Conversion | 0 | July 12, 2010 22:24 |
Tetrahedral and hexahedral mesh based on FVM | kuang | Main CFD Forum | 0 | July 20, 2008 04:52 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
