[ICEM] Meshing Error with a Solidworks Geometry
Old   September 30, 2010, 10:20
Default [ICEM] Meshing Error with a Solidworks Geometry
Fractal is on a distinguished road
Hey Forum,
I am trying to mesh a floor and a diffuser for our FSAE car but it won't properly mesh due to some error shown below.
I used solidworks for my geometry and our car also uses solidworks. ICEM won't import some solidworks files as well for some reason but that's another problem. The error mentioned is "ERROR: Part manager failed to attach assembly".
Any help would be appreciated.
Fractal is offline   Reply With Quote
Old   October 31, 2019, 23:36
Sai Krishna
Sai Krishna is on a distinguished road
Try parasolid x_t format as I also faced this issue.
Sai Krishna is offline   Reply With Quote
Old   November 12, 2019, 12:59
Joshua
jbo214 is on a distinguished road
The Solidworks file format (*.sldprt, *.sldasm) is proprietary. Unless ICEM has licensed the file format reader from SolidWorks (or if there is a version mismatch), you cannot open SolidWorks files directly. You will need to export your CAD file to a non-proprietary file format (*.STEP, *.X_T, *.IGES, *.ACIS) and use that as an intermediary.
jbo214 is offline   Reply With Quote
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
[ICEM] Ship Hull imported geometry nuovodna ANSYS Meshing & Geometry 0 February 25, 2010 10:09
IGES/IGS format geometry file for icem meshing littlelz Main CFD Forum 0 May 27, 2008 18:24
Meshing the geometry Vidya Raja FLUENT 0 February 26, 2006 19:44
meshing geometry in gambit soundar FLUENT 1 January 7, 2005 02:59
