[ICEM] Meshing Error with a Solidworks Geometry |
September 30, 2010, 10:20 |
Hey Forum,
I am trying to mesh a floor and a diffuser for our FSAE car but it won't properly mesh due to some error shown below. I used solidworks for my geometry and our car also uses solidworks. ICEM won't import some solidworks files as well for some reason but that's another problem. The error mentioned is "ERROR: Part manager failed to attach assembly". Any help would be appreciated. |
October 31, 2019, 23:36 |
Sai Krishna
Rep Power: 7 |
Try parasolid x_t format as I also faced this issue.
November 12, 2019, 12:59 |
Joshua
Rep Power: 11 |
The Solidworks file format (*.sldprt, *.sldasm) is proprietary. Unless ICEM has licensed the file format reader from SolidWorks (or if there is a version mismatch), you cannot open SolidWorks files directly. You will need to export your CAD file to a non-proprietary file format (*.STEP, *.X_T, *.IGES, *.ACIS) and use that as an intermediary.
[Gmsh] Problem meshing an imported geometry | Alicia | OpenFOAM Meshing & Mesh Conversion | 0 | March 30, 2010 04:53 |
[ICEM] Ship Hull imported geometry | nuovodna | ANSYS Meshing & Geometry | 0 | February 25, 2010 10:09 |
IGES/IGS format geometry file for icem meshing | littlelz | Main CFD Forum | 0 | May 27, 2008 18:24 |
Meshing the geometry | Vidya Raja | FLUENT | 0 | February 26, 2006 19:44 |
meshing geometry in gambit | soundar | FLUENT | 1 | January 7, 2005 02:59 |
