November 9, 2010, 10:19 |
Surface normals in ICEM
I have recently started using ICEM-CFD for meshing my domain. In fact this is the first time I am using a commercial code for CFD. Please advise what is the role of surface normals in ICEM. Is there a 'consistent' direction of surface normals which one should ensure while meshing the domain? I see a tool 'Modify surface normals'under the Repair geometry tab. Why do we need this?
November 11, 2010, 16:14 |
Thats normal.
Simon Pereira
Rep Power: 47 |
ICEM CFD is a tool with lots of options... They are there for the experts who may want them. If you are new and haven't said "man, I wish I could modify surface normals", you probably shouldn't worry about it. It is rarely needed for CFD (it is taken care of automatically).
Just focus on the few simple steps you actually need to get the mesh you want. This keeps it from getting overwhelming... But since you asked... Some solvers, particularly FEA solvers, are very concerned with surface normals because their properties have a direction... They also come in handy for certain operations, like extrude, where you can extrude by normal instead of giving a direction. |
November 17, 2010, 12:33 |
Thanks Simon for your reply!
I was worried about surface normals as someone suggested that a possible reason for non-convergence of my simulation in CFX could be wrong direction of surface normals while creating geometry in ICEM. Thanks again |
November 17, 2010, 18:16 |
Oh yes, fixed.
Simon Pereira
Rep Power: 47 |
Yes, I have seen that in CFX... Especially if You grow prisms thru a baffle against the wall (quads form on the baffle).
In older versions, the normal of the prisms was not consistent and each column of quad shells would orient based on the line element at the wall (which were not required to be uniform). As a result, some columns had normals facing different than the rest and this caused the problem. But once we heard that this was important, we immediately fixed it so that the entire baffle, including all the prism quad columns, have the same orientation. I have not heard any reported issues since. |
August 12, 2022, 05:44 |
Surface normals
#5 | |
anuj kumar
HY,where i can learn more about these surface normals.I am trying to extrude a mesh using pyhyp script (which requires surface normals to be oriented in a specific way) any idea, on how can i achieve that in icem cfd |
icem cfd, surface normals |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
problem with surface creation in ICEM from multiple curves | dialolema | ANSYS Meshing & Geometry | 2 | October 27, 2014 13:14 |
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface | James Date | CFX | 3 | August 10, 2012 04:47 |
