[ICEM] hybrid mesh
Old   March 5, 2011, 01:21
Default hybrid mesh
Ugly Kid Joe
vmlxb6 is on a distinguished road
There was a thread which talks about hybrid mesh (hexa + tri) but I didnt follow it.
I an simulating a 2-D one way FSI for a flow over a cylinder and want a hexa mesh around the cylinder and tri or quad mesh in the rest of the region. A complete hexa mesh would also do. Since my mesh (cylinder) is moving, there is stretching and expansion of the boundary. I guess having a good hexa mesh should work. I created an o-grid mesh but the corner elements got distorted. I have attached 3 pics. Mesh 3 shows where the distorted elements are, mesh 1 shows the mesh around the cylinder.
http://img717.imageshack.us/i/mesh1.png/
http://img195.imageshack.us/i/mesh2q.png/
http://img694.imageshack.us/i/mesh3.png/
I am looking at something like this:
http://img233.imageshack.us/i/requiredmesh.png/
Thank you.
vmlxb6 is offline   Reply With Quote
Old   March 6, 2011, 15:45
Default Release Orthogonality
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I guess you are using the hexahedral mesh smoother set to Orthogonality.
We are working on improving this smoother so it can relax its orthogonality in a better way, but right now it is trying to apply orthogonality (make the mesh right angles) to the walls and this causes trouble with the 45 degree angles in the corners.
The solution is to release the orthogonality for the FF walls. You will find a control for this where you setup your smoother settings.
At the same time (and with the same option), I suggest you set the initial cell height on the circle so the ortho smoother will control that better and not cause drifting. You can set a specific height if it is constant, but the non-sensical default of -1 means "keep existing height", and is useful if that initial height varies.
The Ogrid method is much more efficient than the HGrid method and much better able to capture boundary layer effects.
PSYMN is offline   Reply With Quote
Old   March 6, 2011, 15:49
Default Circular Far Field...
PSYMN's Avatar
Simon Pereira
One other quick thought... You could have a circular far field. Then you would have a perfectly radial model that could be orthogonal everywhere without any pesky corners.
Old   March 6, 2011, 15:58
Ugly Kid Joe
for a circular far field how do i set the BC ??????? Will it just be inlet ???
I made another mesh which is O-grid at the center near the cylinder and H-grid else where. Could you please have a look at it. Can I can email you the msh file.
I am studying a moving cylinder problem (1 way FSI). And I cannot decide as to what the problem is. I presume the problem may be the mesh deformation at the boundaries.
any idea what should the mess stiffness be ???????
Old   March 6, 2011, 16:25
Ugly Kid Joe
Am attaching some pics of the mesh. Can you tell me if its appropriate for a one way moving cylinder problem ???
Thank you very much.
Old   March 9, 2011, 13:44
PSYMN's Avatar
Simon Pereira
I would probably have fanned out the Hgrid a bit so the perimeter would be uniform spacing, but that isn't necessary... I think it looks good.
I have no idea what to use for stiffness... What are you using to Morph? Does your morpher allow you to move the entire region around the circle so that the boundary layers would be moved as a whole and the interpolation could happen somewhere else?
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] hole in hybrid mesh malkovitch ANSYS Meshing & Geometry 1 June 11, 2010 08:21
Tgrid Hybrid mesh JSM FLUENT 2 December 4, 2007 23:03
hybrid mesh SC Hu FLUENT 1 December 23, 2000 15:40
