[ICEM] Problems with hexa mesh around wheel
Like Tree1Likes
  • 1 Post By PSYMN
Old   February 24, 2011, 09:11
Default Problems with hexa mesh around wheel
HerrOlsson is on a distinguished road
Hi, I'm new to this so don't call me stupid just yet, please
As an assignment in uni I'm going to mesh a rotating wheel with hexa cells. I'm having some problems with the cells on the side of the wheel as shown in the pictures, with skewed cells.
Any suggestions will be greately appreciated!
HerrOlsson is offline   Reply With Quote
Old   February 25, 2011, 15:50
Default Cylinder, not sphere...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Your problem is trying to map an HGrid block to a circle (the face of the wheel).
You need to move the HGrid further into the wheel and then split the surrounding OGrid so that the elements near the edge are alinged with the surface of the wheel and the transition between OGrid and HGrid happens further in where the HGrid is not forced open toward 180 degrees.
But more than that, you have tried to capture a cylinder with an Ogrid topology better suited to a sphere.
Here is a picture to illustrate what you should have done.
You don't absolutely need to have the OGrid pass all the way out the far field wall, but often it is easiest. Other users have it turn around a couple wheel diameters away from the vehicle toward the middle of the tunnel (sorry, I don't have a non-proprietary picture of that).
Anyway, this should get you going.
jee likes this.
PSYMN is offline   Reply With Quote
[ICEM] Creation of hexa dominant mesh and prism layer gnuboard ANSYS Meshing & Geometry 7 January 11, 2018 04:13
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
