[ICEM] Splitting a block along a stretched egdge
Old   March 17, 2011, 08:47
Default Splitting a block along a stretched egdge
Nakul
vnakul79 is on a distinguished road
I have got a simple cube geometry for which I intend to apply a structured mesh. I am aiming to apply a stretching to one coordinate direction. If I split the blocks normal to this direction after applying the mesh parameters, I end up with two discontinuous blocks with the same mesh parameters (see the attached images). Is there a smart way to leave the overall mesh parameters unaffected while splitting the blocks? I could do the meshing manually after splitting, but with 1000+ blocks, this is quite an effort.
Thanks for your help.
Nakul
vnakul79 is offline   Reply With Quote
Old   March 28, 2012, 22:07
Orcun Kozaka
excolade is on a distinguished road
I am having the same problem. Did you find a workaround for this? Is there a way for inheriting "parent" edge's bunching to its "children"?
Thanks and good luck.
excolade is offline   Reply With Quote
Old   March 29, 2012, 08:27
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
I think you're talking about "match edge", just click on it next to edge parameters in the pre-mesh params. Altough i never tried. i hope this is it
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
[ICEM] how to expand block splitting ringtail ANSYS Meshing & Geometry 5 June 21, 2010 10:37
[ICEM] Hexa to Sweep block conversion pertupd ANSYS Meshing & Geometry 1 June 19, 2010 21:37
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
[ICEM] Splitting edge of block rwryne ANSYS Meshing & Geometry 0 September 1, 2009 10:52
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 13:13
