[ANSYS Meshing] Problem with O-grid in drill pipe
Old   April 10, 2011, 08:55
Unhappy Problem with O-grid in drill pipe
Bahadir
bahadir is on a distinguished road
Hi guys,
I'm new in the forum and leraning CFD recently for my graduation project, so any advice would be very much appreciated.
I created a drill pipe for the fluid path to be stimulated by using O-grid. However when I have a look at angles of grids from quality controls they are not so good. May be I am doing wrong with O grid ? Do some one help me?
bahadir is offline   Reply With Quote
Old   April 11, 2011, 20:26
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Your question doesn't have enough info for me to help you.
And remember, a pictures is worth a thousand words...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   April 12, 2011, 07:13
Default Pipe
Bahadir
Helo Simon.
First of all thank you for trying to help me. My aim to make better the angle distribution in the quality control the range og my angles is 45-88 degrees. Here I attached my pichture i Hope it will help you Pipe.jpg
Old   April 12, 2011, 08:51
PSYMN's Avatar
Simon Pereira
Your angles look fine. Most solvers are happy if you can get it above 9 or 18 degrees. What is your worst angle? What is your worst aspect ratio?
However, you distributions could use some work.
Your radial edges need more nodes and they should be bunched toward the walls to better capture the boundary profile.
Alternatively, you could rescale your ogrid (rather than add more nodes). But you would still want to bunch toward the wall (growth rate of 1.2 or 1.5 away from the wall is common)
Ideally you would have a smooth transition across your model.
You could try running the Orthogonal hexahedral smoother if you wanted.
Old   April 13, 2011, 05:48
Bahadir
First of all thank you very much for helping
My smallest angle is 45 deg. so based on your reply it seems that OK.
I will try to change as you said , hope will work.
Old   April 13, 2011, 08:43
AB
BrolY will become famous soon enough
For your information, with the solver I'm using, if the smallest angle is superior to 18, it's good.
So with 45, you are more than good
BrolY is offline   Reply With Quote
Old   May 4, 2011, 14:51
Germán González Silva
germangsilva is on a distinguished road
Send a message via MSN to germangsilva
hello
another way to improve the quality and appearance of the mesh is to reduce the size of Ogrid.
Blocking> Edit Block> Modify Ogrid
in Modify Ogrid> Method = Rescale Ogrid + Edge (is the radial O-grid selected edge) + Offset = 0.7
germangsilva is offline   Reply With Quote
Old   May 5, 2011, 05:00
Bahadir
Thanks German I will try
Old   May 6, 2011, 11:51
I recommend upload geometry files, blocks to try to help more.
Problem with BC on non-overlapping grid interface Ori Levin FLUENT 1 August 29, 2006 18:32
Problem meshing very thin pipe B. Hemmen FLUENT 2 May 16, 2006 08:29
Unstructured grid problem - Laminar flow pipe Roby FLUENT 0 January 12, 2006 05:54
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
nonstaggered grid problem Zhi-Xing Yu Main CFD Forum 7 August 26, 1998 13:22
