problem with hex mesh for impingement plate
Old   May 10, 2011, 07:33
Default problem with hex mesh for impingement plate
rskrishna87 is on a distinguished road
Hi guys,
I got the folowing message when i was trying to generate hexagonal mesh on an impingement plate:
Running hexa-dominant mesher...
{expecting 2 shells on edge 152 769 found 3
error orienting normals, perhaps there is more than one region
error in output_boundaries
Hex Dominant meshing failed
Performing a mesh flood fill...
element containing material point FLUID_1/EXTENDED_FLUID_2_MATPOINT.1 was not found
done mesh flood fill
Can anyone tell me what is the reason for this?
Thanks in advance,
Krishna
rskrishna87 is offline   Reply With Quote
Moving mesh problem Geon-Hong FLUENT 3 April 5, 2010 03:24
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Mesh Deformation Problem Virag Mishra CFX 0 October 9, 2007 00:37
The problem with GAMBIT - using two mesh sizes. Owen FLUENT 2 June 22, 2005 05:16
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
