[ICEM] Blocking of impeller single blade sector (MRF) |
May 5, 2011, 12:09 |
I'm stumped on the strategy to use to block a single blade sector model of a centrifugal pump impeller. The sector has a single blade, a piece of the casing and shroud. I know there has to be an O-grid around the blade but how do i include blocking to capture the Shroud and casing as well. I know i need to upload pics but unfortunately i cannot. Any advice would be extremely helpful Thanks & Regards LD |
May 6, 2011, 09:28 |
Simon Pereira
Rep Power: 47 |
Then upload a sketch...
Is the blade rotating within the stationary casing and shroud? Often we would put a cylinder between the two (to represent the rotational interface) and block each side separately and then combine them in the solver. Does that simplify things enough for you? Best regards, Simon
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
help : import impeller blade coordinates into turbogrid | darKKnight | Main CFD Forum | 1 | February 26, 2016 04:41 |
pitch blade blocking | vidhya | ANSYS Meshing & Geometry | 2 | May 26, 2011 03:24 |
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance | barak182 | ANSYS Meshing & Geometry | 2 | August 18, 2010 03:07 |
Pitched blade impeller | nyatoto | CFX | 7 | August 16, 2002 03:41 |
Pitched blade impeller | Jennifer Haque | CFX | 0 | June 17, 2002 08:35 |
