[ICEM] Different Surface Mesh size in x than y
Old   June 16, 2011, 09:08
Default Different Surface Mesh size in x than y
pam
Willmann
pam is on a distinguished road
working with ICEM on a mesh of a small rudder (110 mm long).
Since its surfaces are bended in all dimensions, I'm using prism and tetra/mixed meshing.
Problem:
Along the trailing and leading edge I couldn't find a proper mesh setup yet.
The problem is that the velocity gradient transverse to the leading/trailing edge line is very high, resulting in a need for a very fine grid, but along the leading/trailing edge line its much lower (except at the end of the rudder). In order to have not too many nodes I need to find a way to achieve a fine space transverse to the leading/trailing edge while along (except of the end of the rudder) it should be in about 10 times as big.
I was trying with line and surfaces meshes, but couldn't find a way yet.
Question 2:
When trying to use the "create Hex Core" option inside the volume tetra mixed mesh, I hoped to get the far field to be a hex mesh. But i couldn't find a way to make the upcoming hex mesh having a big enough size / starting far enough from the finer grid of along the rudders surface. And ended up with ways too many nodes. I tried all the different options on the "Global Mesh Setup > Volume Meshing Parameters > Cartesian Mesh Type > Hexa-Core Mesh Method" but without success.
Any help is highly appreciated, especial the first question is fundamental to me, my masterthesis time is ticking
pam is offline   Reply With Quote
directionally dependent, icem mesh, mesh size
[ICEM] Using Surface Mesh from ANSA for Fluent Sim tommymoose ANSYS Meshing & Geometry 15 March 3, 2016 17:29
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 11:22
