July 6, 2011, 03:20 |
Blocking of a static mixer
Rep Power: 14 |
Hi there,
I have a question regarding the blocking of a static mixer. In the pipe I have 9 mixing elements protruding to the inside. Now I have no idea how to block this parts. Using the Manual, I figured out to put blocks around these elements, but I am not sure about the collapsing tool and how to use it. May you guys have some good ideas or advices on how to procede. Thank you very much for the help! |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 04:24 |
fprint problem | MASOUD | Fluent UDF and Scheme Programming | 5 | October 30, 2011 16:08 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 05:08 |
enum | MASOUD | Fluent UDF and Scheme Programming | 0 | June 5, 2010 00:49 |
Simulating a static mixer in Fluent | Novice | FLUENT | 1 | January 26, 2009 13:09 |
