[ANSYS Meshing] Very high aspect ratio
Old   August 15, 2011, 03:53
Default Very high aspect ratio
zhao xin
zxin is on a distinguished road
I used Ansys meshing to create a mesh with 10E-6 m first boundary layer height. There are few elements with crazy aspect ratio, around 2000000.....What can I do with this? and unbelieveable I did't get any warning. I used this mesh to run the simulation with double precision and no divergence happened, the result oscillated because of large seperation of the flow. Can i trust this? What can happen with such high aspect ratio?
Thank you
Kind Regards,
zxin is offline   Reply With Quote
Old   August 16, 2011, 04:14
Zhang Yang
swiss_zhang is on a distinguished road
10^-6 m thickness of first Bundary layer? What do you simulate actually?
Let's say the number of Prism Layer is usually between 10 - 15 and the total height of BL depends on the flow behaviour and your expectation. But usually is between cm and m.
Check the physics and think about whether you really need such tiny thin BL.
In your case, if the thickness is 10^-6 (Height )and cell size (Length) is in cm, of course you will get a cray aspect ratio.
swiss_zhang is offline   Reply With Quote
Old   August 16, 2011, 05:26
zhao xin
Thanks for the reply.
I do need the 10e-6 thickness to get y+ around 1, since I have really high pressure and mach number. Actually I am using mm as the cell size, but there is still some crazy elements. I could not get even smaller cell size due to the enormous number of elements already.
And I have 30 layers to get a relative smooth transition from the BL to the normal flow.
Old   August 16, 2011, 05:49
Zhang Yang
Do you simulate supersonic flow?
Old   August 16, 2011, 06:17
zhao xin
No, but the Re is 10^6 with high temperature, small ref.length and high pressure. I used Grid spacing calculator http://geolab.larc.nasa.gov/APPS/YPlus/, to calculate my first layer height. And I also calculate the y+ in the result. I'm sure i need 10e-6.
Old   August 16, 2011, 06:25
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Can you just use wall functions?
Stu
stuart23 is offline   Reply With Quote
Old   August 16, 2011, 08:55
Zhang Yang
Stu
Absolutely right, Why don't you use the wall function?
Instead of creating a very fine mesh in BL, you can use the wall function. Because the Velocity Profile in BL is predictable and therefore is approximated using Wall Function. Since you want to capture more details in the BL, you can use the SST Turbulence Model and Automatic Wall Function.
Old   August 16, 2011, 09:13
Zhang Yang
Actually there are 2 methods to solve the flow behaviour near the wall:
1: Wall Funtion Methode
For wall function: y+ < 300 is ok
delta_y = L*y+ * (74)^2*Re^(-13/14), using this formular to estimate the first node spacing delta_y, if the flow passes over a plate
2: Low-Reynold-Number Methode
For Low-Reynold-Number Methode: y+ < 2
Old   August 16, 2011, 09:17
PSYMN's Avatar
Simon Pereira
Also, aspect ratio isn't everything... You can still have a high aspect ratio (though yours is very very high) and have a happy solver if your angles, skewness, etc. are all still good. This is usually fine with boundary elements...
CFD Online Users Survey
Old   August 16, 2011, 09:23
Stuart Buckingham
Slightly off topic, but can someone advise if multigridding speed up the rate of convergence for very fine prism layers? Because the layer is so thin, the velocity gradient normal to the surface would be very small between cells (i.e. low frequency), and therefore would take a lot of iterations without multigridding. I was just wondering out of curiosity...
Old   August 16, 2011, 09:43
zhao xin
Stu
Yes, I have tried that. Maybe I should stick on the wall function.
Old   August 16, 2011, 09:46
zhao xin
Thanks for your effort. I was too aggressive to get the accurate BL. I will estimate them both.
Old   August 16, 2011, 09:49
zhao xin
It's really high....yeah...but the most amazing thing is i didn't get any warning and it ran very well. Mybe it's not that critical at the boundary.
[GAMBIT] High aspect ratio RGRUIZ ANSYS Meshing & Geometry 17 September 21, 2010 02:24
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 12:01
mesh for a high aspect ratio geometry matthias CFX 3 October 20, 2006 02:55
Aspect Ratio at high turbulent and swirled flows zago FLUENT 0 May 19, 2004 02:37
