[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS
Old   September 15, 2011, 05:14
Default need to convert a cell based geometry into STL or CGNS
Kami
kamran_kibria is on a distinguished road
Hi, I have a 2D geometry of a cell based model of an artery where we have the information (cell center coordinates and radius) of each cell. Vessel wall is composed of thousand of cells. Now I want to use that geometry as an input to ANSYS ICEM but the problem is that the geometry which I have is generated through C++ code. The idea which came into my mind is to some how convert that geometry into CGNS (not sure if it is the right format for my case) and then import that into ICEM. One I will be able to mesh that geometry in ICEm, then I need to do CFD using ANSYS CFX. I am not sure how I will convert that into CGNS.
Could anyone please give an idea which format I should use? CGNS is a right format for this case? if anyone has experience in doing then please give me some suggestions
Thanks
kamran_kibria is offline   Reply With Quote
c++ geometry, cgns, icem input
which is better? vertex based or cell centered? neil Main CFD Forum 1 April 23, 2007 16:54
CGNS unstructured in own solver nico Main CFD Forum 3 May 18, 2006 16:31
develop CFD code based on CGNS vito Main CFD Forum 3 May 3, 2005 11:45
node based or cell centered Ts values acboge FLUENT 0 February 6, 2004 06:41
Cell Vertex Based FVM A. S. Main CFD Forum 1 January 28, 2002 07:46
