[ANSYS Meshing] Match Control causing conflicts
Old   November 22, 2011, 10:26
Default Match Control causing conflicts
Kevin Van Looveren
kvloover is on a distinguished road
I'm currently modeling the flow over louver fins with the same domain as an article to validate some things using Fluent and ansys workbench.
I'm however having trouble matching the top and bottem surface to be able to set up periodic boundary conditions in Fluent.
I've set up match controls on every individual inclined section (can't find a way to select multiple faces in one match control). But when I go to add the vertical segments it gives conflict errors
A picture of one conflict area is in attachment.
If any body can help, I'll greatly appreciate it.
kvloover is offline   Reply With Quote
Old   November 26, 2011, 03:41
Kevin Van Looveren
I've found on this forum a comparable problem, with a reply that it is a bug in ansys 12.1. Does this still hold true for ansys 13, or am i missing something to make it work ?
Old   September 10, 2013, 12:40
RacMat
rvl565 is on a distinguished road
i am facing the same problem... have you found a solution to this yet?
Thanks!
rvl565 is offline   Reply With Quote
Old   September 20, 2013, 10:23
vidyanand
Vidyanand Kesti is on a distinguished road
I face the same problem i used mesh periodic interface in FLUENT
Vidyanand Kesti is offline   Reply With Quote
Match Control and Periodic BC ANSYS 12.1 combustion FLUENT 2 April 3, 2017 03:42
Problems of running Oscillating plate tutorial vovogoal CFX 20 February 4, 2016 07:03
error in two way fsi kmgraju CFX 1 May 2, 2011 02:32
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
maintaining a logarithmic velocity distribution Morten Andersen CFX 1 January 8, 2007 11:37
