[ANSYS Meshing] Merging of surface meshes
Old   September 9, 2013, 13:45
Default Merging of surface meshes
Prateek Anand
Thermal_engg is on a distinguished road
Hey everyone,
I am currently working on a somewhat 3-D rectangular geometry.I made it in DM and then sliced it using a YZ plane so as to form more than one body.Then I meshed each part separately in Ansys Mesher.
Mesh formed on each part is of decent quality.Now I want to rejoin all the parts to make the original single volume.
I heard that Gambit has an option of "Linking faces" to do this.
Can anyone please tell me what is its equivalent in Ansys Mesher?
Any help is appreciated.Thnx
Thermal_engg is offline   Reply With Quote
Old   September 10, 2013, 06:41
sridhar
sridhar.d009 is on a distinguished road
no need to merge in Gambit, you can merge it in solver
sridhar.d009 is offline   Reply With Quote
Old   September 10, 2013, 08:07
Default How to merge in solver
Prateek Anand
Is the solver FLUENT capable of merging the meshes? I am fairly
new to this.Could you please elaborate?
Thnak you.
Old   September 13, 2013, 11:05
sridhar
Dear Prateek Anand
yes it is possible in fluent.
first read one mesh file then read 2nd file through as follows
mesh>>
zone>>
append cas file
then read ur file whatever you want.
Old   September 20, 2013, 10:18
vidyanand
Vidyanand Kesti is on a distinguished road
best you can assign the interface or in ansys mesher you have contacts ,by that you can interface the bodies
I am not clear did you really want separate bodies,if you want a confirmal mesh please make it single volume inDm and take to mesher
Vidyanand Kesti is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] merging hexa meshes feizaghaee ANSYS Meshing & Geometry 3 June 24, 2013 15:56
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
merging the meshes Virag CFX 2 March 5, 2007 06:41
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
