Bromby
Rep Power: 0 ![]() |
I had been using ICEM 13 to import a multiblock PLOT3D file. My university updated to ICEM 14.0 and now I can no longer import the files.
The log window does not spit out any red text errors, but does say this: Running ICEM CFD/CAE PLOT3D Input Interface Vers. 14.0.0 Plot3D file contains 2 block(s) Nodal dimension of block(s): - Block #1: 147 x 12 x 1 - Block #2: 151 x 13 x 1 Skipping block #1 with iblank value 0 Skipping block #2 with iblank value 0 I get the same message whether or not I toggle the iblank option on/off in the plot3d option menu (or if I select the 'take a guess' option). And needless to say, the workspace remains void of any mesh. I also cannot find the format for how to include iblank values in the original file (should be =1 I believe). But I would prefer to forgo iblanking all together because it's not a necessary feature for what I'm trying to do. Thanks for any help you can provide!! Last edited by drbones; January 26, 2012 at 11:58. Reason: spacing |
Bromby
OK, so I have contacted ANSYS through their 'Academic Tech Support'. They were able to recreate the problem, and said it appears to be a bug.
The following was their response: "It seems that V 14 cannot handle iblank arrys - seems to be a bug that has resurfaced. I tried various workarounds without success. Unfortunately, until this is fixed, your best bet is to revert to the older version of the translator. To fix, replace the file (pl3d2domain.exe) in C:\Program Files\ANSYS Inc\v140\icemcfd\win64_amd\icemcfd\output-interfaces " I have attached a zip of the replacement file they sent me. Last edited by drbones; January 27, 2012 at 15:19. Reason: grammar |
iblank, icem, multiblock, plot3d |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 02:28 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
