[GAMBIT] virtual or real meshing
Old   February 9, 2012, 14:47
Arrow virtual or real meshing
heidar jafarizadeh
heidar is on a distinguished road
hi
i am meshing by gambit 2.4, i want to know that what is the differences of virtual geometry and real one?
could you tell me some advantages and disadvantages of virtual versus real geometry?
Best Regards
Heidar Jafarizadeh
heidar is offline   Reply With Quote
Old   February 13, 2012, 01:42
-mAx-'s Avatar
Maxime Perelli
By real entities, you can use boolean tool (unite-substract-intersect). You can also easily delete entities. And split operations are less fastidious as in virtual (for example, splitting a volume with a plane is possible, but in virtual not, thus you have to split edges first, then surfaces...)
But Gambit generates automatically virtual surfaces if you are splitting or merging complex shapes in your geometry.
My advice: do all your boolean operations at the beginning, when your geometry is still real (because with virtuals, it is not possible). Also do all you splits, for your geometry decomposition with real geometry (here create some planes for that).
And finally mesh, (and clean) your geometry (here you will start to get virtual entities)
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
how to hook this udf shanu FLUENT 1 August 26, 2011 10:48
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 00:49
udf error Rashmi FLUENT 0 December 27, 2005 05:35
