[DesignModeler] Bubble column / Airlift Reactor with separate headspace |
March 21, 2012, 04:30 |
Kevin
Hi Everybody,
I have a little beginners Problem using the Designmodeler... I want to simulate an airlift reactor with some special baffles and since I read already a couple of times that a separate headspace filled with only air from the beginning is better if using FLUENT I want to create two cell zones, a lower one with containing water and a small one on top filled with air. When I draw my bubble column I used already many different planes, but the "Surfaces from Sketches" generates me just one single 2D body where I need two... even if I use the button twice, once for the lower part and a second time for the upper sketch separately... there will be just one surface body combining the two as one. I thought about slicing via a rectangular body in the ZX-Plane.. but I dont really know how to do it... all I want is to separate the surface body into two bodies of which edges superimpose so I can export them to the Meshing App and be able to choose a coarser grid for the air filled headspace. |
March 21, 2012, 07:56 |
Raja_Bhai
You do not need to create a body to slice, simply create a plane at desired location and use it to slice.
bubble column, designmodeler, headspace, two cells, two phase |
Bubble Column Modelling | dlaw | FLUENT | 24 | October 31, 2017 06:01 |
bubble column | ken | FLUENT | 1 | June 30, 2013 01:18 |
Modelling a Water-Air bubble column | GerhardHolzinger | OpenFOAM Running, Solving & CFD | 1 | February 28, 2012 04:12 |
bubble rising in a column | swamysrikanth | Main CFD Forum | 2 | September 27, 2010 08:59 |
Help required for CFD simulation of Trayed Bubble Column using Fluent | art705 | Main CFD Forum | 0 | July 15, 2009 04:04 |
