[GAMBIT] How to refine a mesh in a 3D cylinder
Old   March 30, 2012, 20:15
Default How to refine a mesh in a 3D cylinder
Aziz
kbylll is on a distinguished road
Hello
How to refine my volume mesh into a cylinder ?
kbylll is offline   Reply With Quote
Old   March 30, 2012, 22:46
Sarang Dalne
sarangdalne is on a distinguished road
Can you give bit more detail as to what you are trying to do?
Thanks,
Sarang
sarangdalne is offline   Reply With Quote
Old   March 31, 2012, 02:55
Aziz
I have a pipe with a valve, and I would like to refine my mesh at the entrance and exit of the pipe and valve to gain more precision and computation time.
Old   March 31, 2012, 08:06
banty
banty is on a distinguished road
before meshing the hole pipe and valve (Volume meshing), first u place more no of grid point on the edges near the entrance and exit and then mesh the volume.
banty is offline   Reply With Quote
Old   March 31, 2012, 11:05
PSYMN's Avatar
Simon Pereira
If you are trying to refine the volume, you need to create a density box... This is one of the options under the mesh tab. If you create a density region from 2 points, it will create a cylinder. The radius of the cylinder is the mesh size you set times the width (number of elements of that size)...
Basically, a density box or density region is a way to locally control the max size in a volumetric region defined by points or entities.
It only works with tetrahedral meshes and surface meshes created from them (such as patch independent octree surface mesh).
CFD Online Users Survey
Old   March 31, 2012, 11:06
PSYMN's Avatar
Simon Pereira
oops, sorry, you were asking about gambit. Ignore the last response, it was for ICEM CFD.
Old   March 31, 2012, 12:32
Aziz
It doesn't work.
if we take only one cylinder, how to refine the mesh at the entrance?
For your information, I create the cylinder and I draw a line between two points located on the faces of the input and output, then I refine my line and mesh them after i mesh my volume, but it doesn't work.
Old   March 31, 2012, 12:33
Aziz
no problem, it happens. Thank you even when it's the thought that counts.
Old   March 31, 2012, 15:15
banty
hopefully it will help u.plz see section Specifying the Grading Scheme
http://202.118.250.111:8080/fluent/G...ide/mg0302.htm
Old   April 1, 2012, 09:00
Aziz
Thank you, I found the solution.
Just refine the surface mesh of the pipe and also to refine the mesh of a plane that intersects the cylinder 2 and the end must be the volume mesh.
Old   April 2, 2012, 01:18
-mAx-'s Avatar
Maxime Perelli
use size functions...
http://my.fit.edu/itresources/manual...ommands_create
Old   April 20, 2012, 19:54
Aziz
Thank you for your answers, they were very helpful to me.
Banty thank you, your answer was the solution for me.
[snappyHexMesh] SnappHexMesh Mesh creating a Mesh inside a Cylinder? abu OpenFOAM Meshing & Mesh Conversion 1 April 4, 2017 09:57
Gambit mesh for cylinder Kavia FLUENT 16 September 26, 2013 00:34
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
