[ICEM] DESIGN and MESH WIND TURBINE
Old   April 6, 2012, 15:03
Default DESIGN and MESH WIND TURBINE
James Hetfield is on a distinguished road
Hi
where can I learn this stuff?
1- I wanna generate an O-grid around a cylinder
2- a mesh around a wing?
3- designing and meshing around a wind turbine blade+ hub
why there is no tutorial???
I need them for my research but nobody and nothing help me
James Hetfield is offline   Reply With Quote
Old   April 6, 2012, 16:09
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
http://www.youtube.com/user/turboeng...?feature=guide
http://www.youtube.com/watch?v=EknKVAJGEJ8
Far is offline   Reply With Quote
Old   April 6, 2012, 18:25
anyone know how to creat a 2-D O-Grid around a circle?
Old   April 7, 2012, 00:13
Far
Sijal
Are you looking for these?
http://www.youtube.com/watch?v=T2Dxa...sMzS_aGxIys6E=
http://www.youtube.com/watch?v=CYz3H...feature=relmfu
http://www.youtube.com/watch?v=UgEKo...sMzS_aGxIys6E=
Old   April 7, 2012, 00:19
i want something like this
oh GOD, Im so pissed off by ANSYS
no good tutorials for it
Old   April 7, 2012, 00:30
Far
Sijal
easily done in ICEM. wait few moments to get snapshots for this particular problem.
Old   April 7, 2012, 01:21
Far
Sijal
Old   April 7, 2012, 02:11
Far
Sijal
This may help you http://www.cfd-online.com/Forums/ans...mesh-wing.html
Old   April 7, 2012, 12:16
THANKS A LOT
FOR SURE you care about other people
I have some questions:
how did u created the initial surfaces and then deleted the smaller circular one?
and also, about the EDGE ASSOCIATION when you have created the 2-D PLANAR block? To what curves have you associated each edge?
Old   April 7, 2012, 12:33
Far
Sijal
1) create point 0,0,0
2) then two more points 0.5,0,0 and 0, 0.5, 0
3) another two points 10, 0, 0 and 0, -10, 0
4). Now create two circles for points in step 2 and 3 with centre from step 1 and angle 360
5). divide larger circle into four parts, for this you need two more points, so copy each points for larger circle by 90 deg
6). Go to surface panel and create surface for larger circle
7). Use build topology
8) delete newly created smaller circle.
Old   April 7, 2012, 12:35
Far
Sijal
First I made planner block and then associated all four edges (selected in one go) and associated them to all four curves. Same goes for smaller circle when you make the o-grid
Assign different material to inner most block (inside smaller circle)
Old   April 7, 2012, 13:29
I dont understand step7 and 8
where is Build Topology?
Old   April 7, 2012, 13:32
I'll have trouble with this method because I want the left side of the larger circle to be INLET and the right side to be OUTLET
but with this method I cant assign different Boundary Conditions to them
Old   April 7, 2012, 13:49
Far
Sijal
If you use the pressure far field then no problem other wise you have to modify the method, means two edges to two curves and other two edges to two other curves. got it?
Old   April 7, 2012, 13:51
yeah
thanks
Old   April 7, 2012, 14:11
Far
Sijal
what about the wind turbine, should we start working on it with fictitious hub
Old   April 7, 2012, 14:25
I think whatever hub will work
we can start and then if i needed another hub I'd change it myself
thanks for your help
Old   April 8, 2012, 09:16
Far
Sijal
There were three problems present in cylinder case
1. Build topology and delete inner surface (Fig 1)
2. Association of inner circle and assigning different material to inner block (see attached files)
3. Mesh parameters (too many nodes were there)
Old   April 8, 2012, 18:13
thanks A LOT
Old   April 8, 2012, 22:51
Far
Sijal
lets start working on wind turbine
2D Modelling of Horizontal Axis Wind Turbine Richeom Main CFD Forum 1 April 7, 2014 17:43
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 09:32
[Other] ANSYS CFX-Meshing problem of a wind turbine blade Zoe ANSYS Meshing & Geometry 1 July 14, 2010 02:02
how to export a mesh from star design to star cd aounallah Siemens 4 March 6, 2009 06:22
code for mesh generation of turbine blade profile fiaz yohana Main CFD Forum 0 January 24, 2006 15:53
