April 10, 2012, 20:00 |
TurboGrid Application Error
walid mohammed abdel maged
hi everybody,
i beginning to use bladeEditor to send CAD drawing to Turogrid but After define flowpath correct and Exportpoint is also correct When i go to open turogrid have error massage say "Turogrid Application Error" when i open detail found Error "Start and end parametric value are identical." and warning "Trim operation failed to produce any surfaces for surface ExportPoints1_tr_high." what' problem in my work |
July 31, 2015, 17:30 |
David Valladares
Rep Power: 12 |
Hi welaa, now I am having the problem you posted few years ago, so I am interested to know if you solved that problem and how you did it.
Thanks for your time. |
Problem running perturbUCyl | sen.1986 | OpenFOAM | 17 | June 4, 2019 05:56 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
attach/detach (valve opening/closing) | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | March 21, 2009 05:18 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
