April 17, 2012, 07:01 |
Edge parameters problem
Jan H
I'm new to ICEM so please treat me kindly I encountered following problem when generating the premesh: After having generated the initia block, i splited it several times and in the end i got following configuration: 1 2 3 4 5 6 I deleted block 4, because it represents the interior of a wall, which I don't want to simulate, which gave me following config.: 1 2 3 5 6 I did all the assigments and when I change now the edge paratmeters of te horizontal edges of block 6, ICEM channges the node-number of block 2 accordingly. I turned of the 'copy parameters' buton, but it still won't help. How do I change the horizontal node number of block 6 without changing the number of nodes of block 2? Thank you very much, Jan |
Multi element wing 3-d problem: trailing edge resolution | sriram042000 | CFX | 2 | March 13, 2011 05:44 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Through-Flow solver, Leading-Trailing edge problem | Menander | Main CFD Forum | 0 | May 14, 2008 18:14 |
Periodic flow boundary condition problem | sudha | FLUENT | 3 | April 28, 2004 08:40 |
