Ansys Workbench - Structural
Old   July 24, 2012, 09:25
Default Ansys Workbench - Structural
Jean-Philippe Guérin
JPGraphX is on a distinguished road
I would like to know how to insert a pressure on a certain diameter. In my problem, I have a circular disc of 200mm diameter. I need to insert a pressure of 2 MPa in the center of my disc, and on a diameter of 30mm. I can't find a way to add a pressure not on all the surface of the top of my disc.
Thanks for your help,
JP
JPGraphX is offline   Reply With Quote
Old   July 24, 2012, 22:19
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Jean-Philippe,
Well one easy way is to slice your geometry in DesignModeler, then form a new part with all the sub-parts (to have a single mesh), then in Mechanical you can easily select your sub-surface to apply your pressure load.
This is not an elegant way to do it but I think it's the quickest and easiest way (I'm not aware of another way) .
Bon courage
Gweher is offline   Reply With Quote
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 09:23
[ICEM] what does the different ANSYS ICEM and ANSYS Workbench? agungwp ANSYS Meshing & Geometry 8 April 12, 2016 04:51
Macro command combatibility ANSYS workbench Tassos CFX 6 January 13, 2014 04:19
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 12:59
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 14:26
