No library of materials! Help!!!!
Old   August 29, 2012, 14:45
Angry No library of materials! Help!!!!
jake nocciolo
jakenoss is on a distinguished road
So currently I am attempting to perform a modal analysis on the veins in an insect wing using ANSYS 13. My professor asked that i used ADPL and to treat the veins at stiffened shell elements. The ansys at my school does not however have a library of elements, so I can't even use the stiffened shell element. My professor suggested that I manually input the veins into Ansys adpl and also said "Also use thick vein for the leading edge and thin ones toward the trailing edge. It is not necessary to vary the thickness (i.e., taper) for a single vein; use a uniform cross section for each vein." Can anyone help me with this? Or preferably suggest an alternative solution? (maybe workbench?)
P.S.
Here is the error message I get when trying to command prompt the shell63 or even beam3 elements: http://i.imgur.com/scQKj.png
Also, I have the insect wing modeled entirely in SOLIDWORKS.
jakenoss is offline   Reply With Quote
ansys, issues
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 15:49
How to do my own materials library? Luc FLUENT 4 January 22, 2003 20:01
