Advice with my final course project "Twin Screw Pump, Fluid Analysis"
Old   February 18, 2013, 17:52
Default Advice with my final course project "Twin Screw Pump, Fluid Analysis"
Arthur Loginow
Maralady is on a distinguished road
Hello, I am working as the tittle of the thread says in the analysis of the fluid portion, so far water, that goes through a twin screw pump. I do not have too much experience in the CFD field, i have some doubts about it, as:
1. What module should i use? CFX/FLUENT/ANOTHER ONE?
2. If i use CFX should i make the mesh at CFX or using another program?
3. If i use FLUENT should i make the mesh at ICEM?
4. Why should i use another module?
5. Will i have to create a Dynamic mesh?
6. I made the geometry already, and i did several different Negatives (The fluid volume) rotating each of them 36 degrees, this will be helpful or not?
So far i have a lot of question about this project, but i am working on it, the concept that i have in my head so far, is not very clear, i made around 10 different solids, each one is rotated 36 degrees, and a friend of mine and a mentor told me that i will have to use those geometries to simulate the water flow, overlapping each simulation, is this true? Is the right way to proceed?
Here some references as:
Twin Pump Geometry (Just the Screws)
Twin Pump Geometry (With the Case)
Twin Pump Fluid Volume
Your opinion will be appreciated, thanks for your time.
Maralady is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
