April 2, 2013, 11:43 |
workbench FSI -CFX Simulations
I am trying to simulate a rotating propeller immersed in water using two-ways coupling FSI by means of Ansys Workbench. Since I am sincerely newbie without experience with Workbench, could somebody give me an advice which systems should I couple (Transient structure + CFX or multibody dynamics + CFX). The idea is to observe the different streamlines produced by the rotating propeller. The case seems to be not that difficult buy I haven't found any good tutorial.
I will really appreaciate your help!! |
April 20, 2013, 10:30 |
Derek Lastiwka
Rep Power: 16 |
You want transient structural. Set up the FEA case with FSI boundaries and write the case file. You can then open this case file is CFX pre and assign the FSI boundaries. I think ansys has a tutorial if you have access to there customer portal.
Derek Lastiwka Mechanical & Fluids Engineer dlastiwka@graymattereng.com Gray Matter Engineering Inc. |
fsi simulation, propeller, workbench 13 |
1 way and 2 way FSI in ANSYS Workbench with Fluent and ANSYS Structural | jwillie2000 | FLUENT | 6 | November 26, 2017 23:21 |
In CFX workbench, which surface, i have to select | senCFX | CFX | 19 | December 19, 2011 01:31 |
FSI with cfx starting problem | icemaniac178 | CFX | 1 | May 24, 2011 09:46 |
CFX for FSI | icemaniac178 | CFX | 3 | May 14, 2011 01:49 |
FSI in Ansys Workbench + CFX v.11 | nasdak | CFX | 3 | June 22, 2009 08:44 |
