March 21, 2018, 12:11 |
Porous-Jump Problem
Uğur Demir
Rep Power: 10 |
I am having a problem in making porous-jump boundary condition. I need to use porous-jump for my 3D HVAC analysis. How do i model my geometry? Do i need 2 part body? or do i need surface body? Can you please help me? Thank You |
March 22, 2018, 05:33 |
ehsan
Rep Power: 11 |
You do not need 2 parts. Make one part and change the corresponding geometry (wall or interface) to the porous jump BC. |
March 22, 2018, 09:48 |
#3 | |
Uğur Demir
Rep Power: 10 |
Can you share a simple geometry with porous-jump boundary condition? |
March 23, 2018, 03:49 |
ehsan
Rep Power: 11 |
Dear Sherlock,
For example, in the last image you attached, it seems that you have 2 parts. you need to select these two parts from "the tree outline/parts" in the design modeler (from workbench). Now click right and form a new part. Then you would have two bodies but one part. Now you have just one interface between these two bodies and also your mesh would be conformal. this interface would be the porous-jump boundary (you have to change it in the Fluent/boundary conditions from interior to he porous-jum BC). |
March 23, 2018, 04:04 |
#5 | |
Uğur Demir
Rep Power: 10 |
It works. I always tried to use Boolean Operations to make one part. But it deletes the interface. Thank you very much. |
grille hvac bc, grilles, hvac, porous jump, porous jump bc |
UDF for modifying porous jump parameters | twcp0104 | Fluent UDF and Scheme Programming | 0 | December 15, 2016 07:06 |
Porous jump for filter | Saturn | FLUENT | 4 | October 23, 2014 10:44 |
porous jump problem | semo | FLUENT | 3 | July 10, 2013 17:27 |
Porous Jump for 2D Modeling | THC | FLUENT | 0 | January 14, 2013 03:35 |
porous jump boundary jump thread not handled | hari | FLUENT | 0 | March 4, 2006 02:24 |
