Shockwave location RAE 2822
Old   March 11, 2014, 16:29
Default Shockwave location RAE 2822
Mark
mm391 is on a distinguished road
I am doing a CFD investigation on an RAE 2822 Aerofoil using density based and the K-Omega SST model. I have got a result, which looks good apart from the locations of the shockwave.
The shockwave seems to happen earlier on the topside of the aerofoil in my CFD than in the experimental data i've got. I have refined my mesh considerably around the region but nothing seems to correct it. The Reynolds number is 6.5e+06 at Mach 0.725. I worked out my speed to be 246.7001 m/s given a temp of 288 kelvin and 1 atmosphere, giving me a chord length of 0.3855. The only reason I can think my shockwave maybe wrong is because I have miss calculated the chord length.
Can anyone suggest something I may be over looking? I have attached a matlab picture of the pressure coefficient vs. aerosol length. The experimental data is the red line and my data is in blue.
Many Thanks
Mark
p.s I am using Fluent to solve and created an unstructured mess with an inflation layer that has a Yplus value that fall within the correct parameters.
mm391 is offline   Reply With Quote
Rae 2822 bharatiaero Main CFD Forum 5 December 31, 2022 13:15
transonic RAE 2822 Airfoil grid..help Michel Main CFD Forum 6 April 14, 2019 08:45
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
2D c-mesh around RAE 2822 profile CFD student Main CFD Forum 2 September 7, 2004 11:03
Urgent: RAE 2822 validation NID Main CFD Forum 0 September 3, 2004 10:34
