How to divide the region for 3D geometry in ANSYS CFD Post
Like Tree1Likes
  • 1 Post By kwg
Old   November 26, 2014, 21:21
Default How to divide the region for 3D geometry in ANSYS CFD Post
Naimah
wanna88 is on a distinguished road
I have a complex and irregular shape of the geometry (Please find the attached file)
May I know, how to divide the geometry into different region and calculate for the volume for each region.
Thank you
Naima
wanna88 is offline   Reply With Quote
Old   November 27, 2014, 09:22
kwg
Koen
kwg is on a distinguished road
Any chance you divided the domains before the simulation? In CFX Post you can put "=volume()@S1" in a table to calculate the volume of a domain, where 'S1' is your domain name. If it is just one domain, then I don't know how to do this in Post..
If you have the CAD-files where they are specified as different parts, you could specify them as different domains in CFX-pre and then run the simulation. Then you can gather information for a specific domain.
kwg is offline   Reply With Quote
Old   November 27, 2014, 23:23
Naimah
Thank you KWG for the useful information.
I have tried out the example of equation that you had given.
Let say I want to calculate the volume of velocity lambda-2 in a domain name as volume 2.
But the error message pop up (Please find the attached file).
May I know, how to solve for this.
Thank you again
Naimah
Old   November 28, 2014, 03:45
kwg
Koen
Your second picture (which says syntax error) is because you shouldn't use the ''='' when you write an expression. Your first picture, from what I understand, is that CFX is expecting zero arguments in the formula for volume. You put "velocity lambda-2" in the expression, but you should just leave it blank.
You can either write the formula in a table (picture 1) or as an expression (picture 2) to calculate the volume of a domain. Note that in the expression you don't use the "=".
Let me know if this is exactly what you want and if this solves your problem.
wanna88 likes this.
Old   November 28, 2014, 04:24
Naimah
Hi KWG,
It is very helpful. Thank you so much.
I have 1 more question,let say I have region of interest (ROI)(as in the circle in the attached file).
I can calculate the volume of that region based on the method that you showed.
If I want to calculate the volume of variable eg velocity lambda-2 at certain threshold at that ROI, how i am going to do that? Is that Possible?
Thank you
Naima
Old   November 28, 2014, 04:43
kwg
Koen
I don't think that is possible. From what I found in the CFX reference guide is that you cannot define any argument in the volume formula. I am also not familiar with this variable velocity lambda-2, what does it represent?
From the CFX Reference Guide:
14.5.29. volume
Calculates the volume of a 3D location.
volume()@<Location>
where:
• <Location> is any 3D region (such as a domain or subdomain). An error is raised if the location specified is not a 3D object. For details, see volume (p. 177).
Old   November 28, 2014, 04:54
Naimah
Thank you KWG,
As far that I understand lambda-2 is the indication which part is consider as a vortex.
Actually my main interest is to know whether the volume of this lambda-2 at certain part can be calculated or not.
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
[Other] Modification of multi region heater tutorial geometry mukut OpenFOAM Meshing & Mesh Conversion 2 October 4, 2013 20:59
Export geometry file from ansys mechanical browns6 Structural Mechanics 0 August 27, 2013 16:19
Free UK seminars: ANSYS CFD software Gavin Butcher CFX 0 November 23, 2004 09:13
