April 29, 2015, 23:33 |
"Negative Damping" result on aqwa
Tan Siun Seng
Rep Power: 11 |
Hai. Recently doing the analysis for the interaction between bodies for time response analysis of ansys aqwa.
For the irregular wave analysis which involve the convolution, the analysis is completed and results shown, but with the info of "NEGATIVE DAMPING". May i know what is "NEGATIVE DAMPING" by meaning here? Should i ignore the "NEGATIVE DAMPING" info? (Yes/No) Why? If NO, which parameter or option i should edit? Thanks in advance. |
January 11, 2017, 06:04 |
Simon
I do not know you model in detail and I also do not know AQWA well. However, here's one possible explaination: Negative damping can occur when the keel of a vessel is close to the seafloor or when vessels are close to each other. In that cases, the water gets "pushed" against the opposing surfaces. This "spring effect" can be captured as negative damping. So there may be the possibility, that your negative damping is real. Cheers Simon Edit: Sorry, I didn't realize that this post is really old. I did not mean to be a gravedigger here... |
Unable to get the expected result in Electro-thermal-structural problem | jatin1990 | Structural Mechanics | 0 | April 8, 2015 08:17 |
Comparison the airfoil 0012 experimental result and simulation result | harrislcy | FLUENT | 30 | August 29, 2013 10:27 |
How to display the whole result of a periodic model via one period result? | dixylo | FLUENT | 2 | February 23, 2012 04:11 |
Read Result Files or User Defined Result | Aquilaris | ANSYS | 0 | February 9, 2011 05:25 |
LES result | harrislcy | FLUENT | 1 | December 28, 2009 06:29 |
