June 21, 2015, 11:49 |
Problem with automatical mesh in ICEM
Hi everyone,
I have a geometry portion of a francis turbine runner. When i try to mesh it i get meshed only a pice of this portion (image below). I have tried whatever i knew but always happen the same. Could someone help me? Many thanks |
June 22, 2015, 07:38 |
Vik
Rep Power: 10 |
You tried to unite them into a single geometric. That is the beginning geometry
trying as shown below (image below) before http://i.imgur.com/E7VQsMB.jpg after http://i.imgur.com/BmS7vkk.jpg maybe help you |
June 22, 2015, 13:02 |
Many thanks Green52. I have ben studying this problem with other shapes and I have realised that this only happens when I import Geometries into an other one or when I transform them (rotate,...).
Im sure is because of u have told me. I will try to find a solution about how to unite both geometries in one solid. Thanks again |
June 23, 2015, 03:07 |
Vik
Rep Power: 10 |
with pleasure, anytime with pleasure
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ICEM] Mesh Extrusion problem in ICEM | James Hetfield | ANSYS Meshing & Geometry | 0 | July 8, 2012 15:42 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 06:28 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
