Inflation error in narrow passage
Old   August 11, 2015, 18:25
Default Inflation error in narrow passage
shubham khadria
shubhamkhadria is on a distinguished road
I am fairly new to CFD and am working on meshing a complex flow domain in ansys mesher for CFX. There are named sections in the passage and due to narrow passage(along axial direction) inflation is showing error. I am not able to continue ahead. I tried playing around with the settings of inflation (growth rate, number of layers, inflation option) but nothing is working.
Can anyone help me on this issue?
Thanks in advance
shubhamkhadria is offline   Reply With Quote
Old   August 11, 2015, 18:40
Kapi is on a distinguished road
post a pic with the problem area of mesh and one with the settings you are using!
Kapi is offline   Reply With Quote
Old   August 18, 2015, 11:32
Neo_Zeo is on a distinguished road
Originally Posted by shubhamkhadria View Post
Thanks in advance
Try to increase the "num cells across gap"
Neo_Zeo is offline   Reply With Quote
Old   September 1, 2015, 09:06
Wang Zhe
Asura is on a distinguished road
You may try with the advanced size function: Proximity and Curvature. It may probably solve your problem.
Thanks.
Regards,
Wang Zhe
Asura is offline   Reply With Quote
ansys, cfx, error, inflation, mesh 3d
[ANSYS Meshing] Inflation Layers Being Finicky Markua ANSYS Meshing & Geometry 12 April 28, 2015 07:11
Fluent diverges when using inflation layers ziggo FLUENT 4 August 9, 2013 12:11
[TGrid] Inlet passage in turbogrid. soldimix15 ANSYS Meshing & Geometry 0 September 5, 2010 11:34
Large Valve Flow Analysis - Inflation Problem sercan85 ANSYS Meshing & Geometry 2 June 1, 2010 14:02
Inflation Gab CFX 6 August 24, 2005 22:45
