August 19, 2015, 21:44 |
Negative cell volume. Where?
Kegan Leckness
Rep Power: 11 |
Hi all,
I am receiving the error described in the thread title from my Fluent/ANSYS two-way FSI analysis. I have multiple fluid domains separated by solid domains. How can I determine where this volume is detected? Regards, Kegan |
September 15, 2015, 17:04 |
Kegan Leckness
Rep Power: 11 |
Thank you for your suggestion.
Won't checking the contour only show me the elements on a particular face? I suspect the cell(s) with negative volume are in the interior of the fluid domain. I've plotted a Volume Rendering of variable: cell volume derivative. There doesn't seem to be any good definition of what this variable represents in the HELP documentation or in the forums. Some of these values are reported as being negative near the FSI interface (at the location I suspect poor elements will occur). Is this the best way to search for poor quality elements in CFD-Post? Kegan |
September 16, 2015, 19:30 |
#4 | |
Rep Power: 15 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
Warning: negative cell volume detected! | boboroo | FLUENT | 7 | February 11, 2018 03:38 |
Negative Cell Volume with moveDyMEngineMesh with Foam Extend 3.0 | RJ87 | OpenFOAM | 2 | May 8, 2014 12:13 |
Negative cell volume problem | schuny | FLUENT | 8 | April 10, 2012 05:16 |
negative cell volume | alfin | FLUENT | 2 | January 19, 2006 20:17 |
