Home > Forums > Software User Forums > ANSYS
HELP! Regards to Square Cylinder!
Old   February 3, 2016, 01:51
Default HELP! Regards to Square Cylinder!
Quek
Quek is on a distinguished road
HI i have a problem of getting the Cd and Cl values and i think is due to the meshing method i use. Can anyone advise in this?
This existing results using Re=20, which calculated at velocity,v, of 0.00029m/s, with the default setting of density and viscosity. My dimension modal is 1m X 1m X 10m, which L=1m, D=10m. The boundary area is about 4D on both sides and height is also 4D from the top of the body.
Meshing method is in default setting. With this mesh i managed the iteration while calculating doesnt have any reverse flow occurs. However my Cd and Cl values are too small which considered to be zero.
I have tried many method example from the given link:
http://www.cfd-online.com/Forums/ans...dral-mesh.html
This method given a problem of having reverse flow instead.
Can anyone please advise how to get the meshing correct in order to get my results and compared with the existing results?
Anyway im doing a project to illustrate the air flow around tall buildings.
Quek is offline   Reply With Quote
[ICEM] Flow over 2-d square cylinder GAURAV KUMAR ANSYS Meshing & Geometry 1 March 2, 2015 12:26
Undergrad Civil Student: need help with simulating 2d flow past a square cylinder Karim Byasse Main CFD Forum 0 May 5, 2012 22:58
LES of a square cylinder gfilip OpenFOAM Running, Solving & CFD 1 June 24, 2010 12:33
solving airfoil like square cylinder problem? zonexo Main CFD Forum 1 May 27, 2006 15:16
drag calulation over a square cylinder sex00 Main CFD Forum 4 February 2, 2001 07:16
