Impact of closing door (sliding) on a person
Old   August 31, 2016, 07:38
Default Impact of closing door (sliding) on a person
anthonyishere is on a distinguished road
Hi all,
I need some tech help.
I need to know if we can simulate the below scenario:
A sliding door is made up of steel. It has a rubber beading (cross section known) at the edge. The door slides to closed position with a certain speed.
Can I model and analyze the force which will act on a person trapped between the doors.
Thx
AD
anthonyishere is offline   Reply With Quote
Old   September 5, 2016, 00:47
Kapi is on a distinguished road
yes, you can place a body between door opening and closing position and measure it on the surface of body
Kapi is offline   Reply With Quote
Old   September 5, 2016, 01:23
Hi Kapi,
Thx for the reply. I was planning to undertake the analysis in ANSYS. So how do I go about it. I thought of simplifying the problem into only modeling the rubber bead. One end the force of the closing door will act and the other end the body will act as the "stopper".
Do you have any suggestions as to whether this approach is correct and also what parameters I should assume for simulating the rubber and the human body properties?
Thx in advance.
Anthony
ansys
Particle Impact Angle for Expressions in CFX mabna CFX 0 June 17, 2015 19:28
impact force (shear stress) by waterjet impingement herozhu Main CFD Forum 0 May 7, 2014 20:39
Bai model droplet-wall impact / elastic rebound crevoise STAR-CD 3 November 15, 2012 14:06
Impact velocity and angle from DPM model in Fluent eng775 FLUENT 0 September 4, 2009 14:34
Plotting particle wall impact angle (Lagrangian pt Bart Prast CFX 0 January 26, 2009 04:23
