How to set the velocity inlet angle for cassette air conditioner |
June 6, 2017, 21:38 |
Selangor
Rep Power: 8 |
Hi there,
I have issues with setting the velocity angle, I'm not too sure how to begin as I'm new to this software. Hope that someone could help me with the velocity inlet angle setup. |
June 7, 2017, 00:24 |
Cartesian components
Svetlana Tkachenko
Rep Power: 14 |
It is probably more intuitive to specify the velocity Cartesian components (rather than magnitude and direction). Do a hand calculation to find what the components are, and then put them into CFX.
June 7, 2017, 01:50 |
Selangor
Rep Power: 8 |
Hi Светлана,
Thanks for the quick response and the suggestion. Appreciate it a lot. I did some manual calculation but i'm not sure whether is right. The following attachments are the calculations i did, would u mind checking it for me? Mistake on the calculation: x-component is +5.2 m/s & z-component is +5.2 m/s |
June 8, 2017, 22:48 |
Confirm angles
Svetlana Tkachenko
Rep Power: 14 |
It looks confusing, let's start with talking about what information you already know. Did I draw it correctly in the attachment? Angle BAC is 30°, and angle BAD is 45°?
June 9, 2017, 04:00 |
Sorry for the confusion
Selangor
Rep Power: 8 |
Hey,
So sorry for the confusions. I had calculated wrongly and the following pictures are the correct 1. Hope that it is clearer to you this time. Thank you. |
air condition simulation, velocity angle, velocity inlet |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
A rotating blunt body within a "box" of air at an angle? | li0012in | CFX | 1 | January 11, 2012 19:25 |
How to set pressure & velocity in inlet B.C??? | asghari | FLUENT | 2 | February 7, 2007 08:00 |
Urgent! Help on UDF to set inlet velocity | Ray Hong | FLUENT | 4 | December 30, 2005 12:32 |
Cannot set correct inlet velocity by UDF?!? | Bob | FLUENT | 5 | March 27, 2003 03:17 |
