May 24, 2017, 12:49 |
Suppres verify box / clear command
Tim
Rep Power: 13 |
Noob Ansys user here....
In ansys APDL, the /clear command brings up a pop-up box saying 'SHOULD THE /CLE COMMAND BE EXECUTED?' with Yes + NO buttons to click. I have written a script to read in a database, perform some operations, clear the database load in a second database, perform the operations again and so on. The script uses the /clear command. My question is how to suppress the Yes / No verify box so I can let this run overnight without any human interaction. I have researched this a bit and found the /NERR command isn't much use as the message isnt an error or a warning and also not had much luck with /UIS either Do you lovely people have any suggestions or experience with this? Any suggestions would be very welcome :-) |
I get different results when I scale the 'falling box' tutorial | Hossein1 | FLUENT | 7 | August 19, 2017 02:52 |
[surface handling] Command line tool for finding the bounding box of an STL file | terrybarnaby | OpenFOAM Meshing & Mesh Conversion | 8 | November 4, 2016 13:09 |
[DesignModeler] simply model, empty box | conquer | ANSYS Meshing & Geometry | 0 | March 28, 2014 18:26 |
SnappyHexMesh plane surface bounding box | podallaire | OpenFOAM Bugs | 22 | August 26, 2009 07:34 |
Immersol Simulation of a Heated Box | Dong | Phoenics | 0 | March 2, 2006 21:20 |
