September 13, 2017, 05:37 |
How to import Temperature data's in to ANSYS
Rakshit
Rep Power: 8 |
Hi all,
I am dealing with heat transfer related to conduction in solid bodies and I wanted to solve this for transient temperature( here my boundary condition is only temperature hot and cold on either side of the wall), I have some temperature data's in my excel file, and I want to import it to Ansys workbench. I am stuck in this step, so could anyone can help me at this stage?? Advance Thanks for your help |
September 25, 2017, 03:21 |
Gwenael H.
Rep Power: 20 |
If you need to apply a temperature variation that is “constant” over a surface (your BC hot / cold) you can insert a temperature BC and change the value to > tabular and insert your excel data directly. If you have a spatially varying temperature distribution that changes over time then you can use the external data module in Ansys Workbench and map it to the desired faces. Have fun |
October 9, 2017, 14:01 |
Rakshit
Rep Power: 8 |
Great Many Thanks
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
How to import RTH file to ansys workbench | Gang | ANSYS | 0 | July 24, 2014 11:59 |
[DesignModeler] Import mesh into ANSYS | hityangsir | ANSYS Meshing & Geometry | 0 | January 25, 2014 11:44 |
Can I import complex geometry into Ansys Multiphysics? | mikejost | ANSYS Meshing & Geometry | 1 | December 5, 2010 20:06 |
import Fluent data&case to ANSYS | Vlad S | FLUENT | 0 | April 2, 2003 05:49 |
